Opening a Device
  1. Open NxView from your computer’s start menu.
  2. After the program has launched you should see the camera list of NxView as in the image below. The list contains all currently available cameras, including File Cameras (file camera icon) and Virtual Cameras (virtual camera icon).
Hint
Have a look on our guides on the usage of File Cameras and Virtual Cameras.
The start-up interface of NxView showing a list of cameras.
  1. If your device is shown as Available and without any warnings, just double click on it. You can open multiple devices by first selecting the devices and then click on the Open button in the upper right corner of the window.
    Trouble-Shooting:
    - My Device Is Not Listed
    - My Device Shows a Warning
  2. Your device is now open and you can see a you with a color coded depth image of the scene like it is shown in the image below.
    Trouble-Shooting:
    - The 3D Data is Bad
    - The MTU is Low
NxView showing the depth image of an opened camera.
  1. Now that your camera is up and running you can have a look at the rest of our guides for more advanced topics.
Hint
Need Support?
If you followed all the other troubleshooting guidelines and NxView still cannot find your camera, check out the Ensenso Community or contact the IDS support.
Trouble-Shooting
If NxView cannot find your camera, there is probably a problem with your network configuration. The Network Wizard will help you to set everything up correctly.
When NxView still cannot find your camera after you ran the Network Wizard, you should check the following troubleshooting guides:
Does the device have power? Does its LED light up?
  • For N-series cameras: Does the network cable provide power through PoE?
  • Does the power supply provide enough power according to the specifications?
If your camera is listed but shows a warning, the following troubleshooting information will help you resolve this warning:
If you assembled an X-series device yourself, you will first need to pair the projector with two monocular cameras. Select the projector and then click the Calibrate... button to start the calibration wizard. After the calibration procedure the X-series stereo system behaves just like an N-series camera.
XR-series cameras will automatically pair with the attached cameras when powered on.
The 3D Data is Bad
If you cannot see meaningful 3D data, please make sure that the distance between the camera and the scene objects is appropriate for your camera model. You might now also want to take a look at the camera setup considerations and Parameter Adjustment.
Changes in temperature and forces from mounting the camera can also change the camera’s internal geometry and lead to an incorrect calibration. Check the calibration as described in this guide.
The MTU is Low
If you are getting warned about a low MTU please see the section Maximum Transmission Unit (MTU) in the Network Performance guide for help.
