Workspace Calibration
With a workspace calibration you can change the coordinate system of the PointMap by using a calibration pattern as a reference.
This how-to shows how a workspace calibration can be done with the NxLib. If you only want to do it once, you can also use NxView. Simply open the camera that you want to calibrate and choose the “Workspace Calibration” Mode.
To perform a workspace calibration, you will need the following steps.
  • Place a calibration pattern at a known point of your desired coordinate system (e.g. the origin) such that the camera can see it.
  • Take an image with the Capture command.
  • Search for the calibration pattern with the CollectPattern command.
  • Compute the pose of this pattern with the EstimatePatternPose command.
  • Execute the CalibrateWorkspace command. Use the estimated pattern pose from the previous step as the (PatternPose) parameter and give the desired pose of the calibration pattern in your new coordinate system as the
    (DefinedPose) parameter.
  • When the command is done, you can continue with grabbing 3D data. The points will now be in your new coordinate system.
The calibration only persists until the camera is closed. To permanently store it on the camera, you can execute the StoreCalibration command with the (Link) parameter enabled.
  • To get better calibration results, you can take multiple images of the same calibration pattern and use the (Average) parameter for the EstimatePatternPose command.
  • After mounting a camera at a new position, it might be useful to perform a recalibration. This can be done with the patterns that you collected for the workspace calibration anyway. See this how-to for a code snippet that performs a recalibration and can be inserted into the example code below.
Code Examples
We assume that the camera with serial “1234” is already open. See here for information on how this can be done.
// Turn off the camera's projector so that we can observe the calibration pattern.
NxLibItem()[itmCameras]["1234"][itmParameters][itmCapture][itmProjector] = false;
NxLibItem()[itmCameras]["1234"][itmParameters][itmCapture][itmFrontLight] = true;
// Clear the pattern buffer in case there are any old observations in it.
NxLibCommand(cmdDiscardPatterns).execute();
// Take some images and search for the calibration patterns in them.
for (int i = 0; i < 10; i++) {
	NxLibCommand capture(cmdCapture);
	capture.parameters()[itmCameras] = "1234";
	capture.execute();
	try {
		NxLibCommand collectPattern(cmdCollectPattern);
		collectPattern.parameters()[itmCameras] = "1234";
		collectPattern.execute();
	} catch (NxLibException&) {
		// Could not find any calibration patterns...
// You can insert a recalibration here, as you already captured stereo patterns anyway. See here for a
// code snippet that does a recalibration.
// Estimate the position of the calibration pattern. We increase the precision of this step by averaging
// over all of the collected pattern positions.
NxLibCommand estimatePatternPose(cmdEstimatePatternPose);
estimatePatternPose.parameters()[itmAverage] = true;
estimatePatternPose.execute();
// Perform a workspace calibration with the estimated pattern pose as input. At this point you could
// also specify the target location of the calibration pattern with the DefinedPose parameter. Leaving
// it empty will set the calibration pattern to the origin of the new coordinate system.
NxLibCommand calibrateWorkspace(cmdCalibrateWorkspace);
calibrateWorkspace.parameters()[itmCameras] = "1234";
calibrateWorkspace.parameters()[itmPatternPose] << estimatePatternPose.result()[itmPatternPose];
calibrateWorkspace.execute();
// Store the new calibration to the camera's EEPROM.
NxLibCommand storeCalibration(cmdStoreCalibration);
storeCalibration.parameters()[itmCameras] = "1234";
storeCalibration.parameters()[itmLink] = true;
storeCalibration.execute();
// When you compute a point map now, the result will be in workspace coordinates.
To check the calibration, there is a code snippet that does a recalibration. See here for a code snippet that does a recalibration.
