Hardware Installation
This section describes how to set up your Ensenso stereo camera after completing the software installation.
Hint
If you do not have a hardware camera yet, you can also start by using the sample data.
Connection and Power Supply
Connect your Ensenso camera to a free Ethernet port of your system. B-, C-, N- and S-series devices can be powered directly via PoE. X- and XR-series cameras need a separate 24 V supply. See the Power Supply topic for details.
Caution
cautionHot Hot surfaces!
All cameras may exhibit high housing surface temperatures when operated at high environment temperatures and/or high LED flash duty cycle times!
Checking the Calibration
Forces from mounting the camera can slightly change the camera’s internal geometry and lead to an incorrect calibration. We recommend to check the calibration after mounting as described in this guide.
