Using Sample Data from the Ensenso Website
1. Download Data
We provide sample data for different scenes on our website. Go to https://www.ensenso.com/sample-data/ to download zip files that contain raw image data. These files can be used as a file camera in the NxLib and NxView.
2. Create a File Camera in NxView
../_images/test_data_1.png
  • Open NxView.
  • Select Create... → File Camera.
../_images/test_data_2.png
  • In the appearing dialog, select the zip file you downloaded above by clicking on ... next to the zip file path field.
  • A serial number will automatically be generated from the file name of the zip file, but you can change it if you want.
  • Confirm with the OK button. This will create the camera and close the dialog.
3. Open the Camera in NxView
../_images/test_data_3.png
  • The newly created file camera is now listed in the camera selection dialog.
  • Select it (if there is more than one camera in the list) and click the Open... button.
../_images/test_data_4.png
  • NxView will open the camera and display its depth data.
  • You can now adjust the matching parameters as described in this guide.
  • If you want to use the test data in your own application, please read the guide on using file cameras.
