Getting Started
Software
Hardware
Guides
About
Compliance
B
Certification
Illumination Hazards
Intended use
Safety Instructions
Disposal
C
Certification
Intended use
Safety Instructions
Disposal
CR
Certification
Intended use
Safety Instructions
Disposal
N3x
Certification
Intended use
Safety Instructions
Disposal
N4x
Certification
Intended use
Safety Instructions
Disposal
S
Certification
Intended use
Safety Instructions
Disposal
X
Certification
Intended use
Safety Instructions
Disposal
XR
Certification
Intended use
Safety Instructions
Disposal
Calibration Patterns
Specifications
100 × 100 × 1 mm, 12 mm Grid Spacing
200 × 200 × 3 mm, 24 mm Grid Spacing
390 × 390 × 4 mm, 48/96 mm Grid Spacing
Dimensions
Hardware Guides
Mechanics
Ambient Conditions
Temperature Ranges
Housing IP Rating
Calibration Stability
Example
Cleaning
Dimensions & Mounting
CAD-Models
B
C
Mounting
Dimensions
C…-S
C…-M
C…-L
CR
Mounting
Dimensions
CR…-S
CR…-M
CR…-L
N3x
Mounting
Dimensions
N4x
S
X
X30/X36-xCP Dimensions Without Extensions
X30/X36-xCP Dimensions With 100 mm Baseline Extensions
X30/X36-xFA Dimensions Without Extensions
X30/X36-xFA Dimensions With 100 mm Baseline Extensions
XR
XR30/XR36-xFA Dimensions Without Extensions
XR30/XR36-xFA Dimensions With 100 mm Baseline Extensions
Vibration / Shock
B-Series
C-/CR-Series
N3x-Series
N4x-Series
S-Series
X-Series
XR-Series
Electronics
Accessories
Network Cables
M12 X-Coded to RJ45 Cables
PushPull to RJ45 Cables
GPIO Cables
Adapter Cable: M12 5-Pin - M8 4-Pin
Adapter Cable: M8 4-Pin - M12 5-Pin
M8 4-Pin Universal Sync Adapter
M12 5-Pin Cable (Open Endings)
M8 4-Pin Cable (Open Endings)
Sync Cable: M8 4-Pin - Binder 712 8-pin
Sync Cable: M8 4-Pin - Hirose 6-pin
Sync Cable: M8 4-Pin - Hirose 8-pin
Power Supplies
M12 5-Pin Power Supply
PoE++ Injector, 90 W, AC Input
PoE++ Injector, 90 W, DC Input
Other power supplies
GPIO Port
B
C
CR
N3x
N4x
S
X
XR
Illumination
B
Risk Group
Exposure Time Limitations
C & CR
Risk Group
N3x
Risk Group
N30/N35
N30/N35 Rev. 2
N31/N36
N4x
Risk Group
S
Risk Group
High temperature operation
Low temperature operation
General Laser Data
X & XR
Risk Group
Power Supply
B
Power-over-Ethernet (PoE)
DC Supply
Long Cable Lengths
Calculation Examples
Example Current Draw Plots
FlexView 4, 10 ms Exposure
FlexView 1, 120 ms Exposure
C
DC Supply
Long Cable Lengths
CR
DC Supply
Long Cable Lengths
N
S
X
XR
Camera Description
Camera Protocols
General Series Features
Housing
Projection Color
Resolution
Texture Images
Performance
Naming Scheme
B-Series
C-Series
Full Specification
CR-Series
N-Series
S-Series
X- & XR-Series
Hardware Specification - Ensenso SDK
Dimensions
(B-Series)
Dimensions
(B-Series)
Weight:
1100 g
Case Dimensions:
