Dimensions
(X-Series)¶
Weights:
Models |
kg |
X30/X36 without extensions |
1.1 |
X30/X36 with 100 mm baseline extensions |
1.7 |
X30/X36-xCP Dimensions Without Extensions¶
All dimensions are measured without cabling. The length of the lenses varies with the lens type. The size will also increase slightly with increased vergence angle of the cameras.
X30/X36-xCP Dimensions With 100 mm Baseline Extensions¶
X30/X36-xFA Dimensions Without Extensions¶
All dimensions are measured without cabling. The length of the lens tubes varies with the lens type. The size will also increase slightly with increased vergence angle of the cameras.
X30/X36-xFA Dimensions With 100 mm Baseline Extensions¶
