Power Supply
(XR-Series)
The XR30/XR36 projection units must be supplied via a 24 V 5 A DC supply on the “External” GPIO port.
Camera Power Supply
The projection forwards the external supply voltage to the left and right camera GPIO port.
Average vs. Peak Power Consumption
Due to limited space the projection unit cannot buffer energy for an entire flash in internal capacitors. Therefore the peak power consumption of 5 A is reached during flashing of the projection LED. The absolute maximum flash time is hardware limited to 160 ms. The hardware limit for the LED duty cycle is 10 %.
Minimum Input Voltage
Depending on the supply cable length and diameter the input voltage at the projection unit will drop below 24 V during flashing of the LED, i.e. during the peak power consumption phase.
The minimum voltage for guaranteed stable operation of projection unit and attached cameras is 16 V. The input voltage at the “External” port must not drop below this voltage at all times.
When powering the camera over longer distances you need to make sure to use wires of sufficient diameter to provide enough input voltage for stable operation of the projection unit and the attached cameras.
