Dimensions & Mounting
(N3x-Series)¶
Mounting¶
N3x-series cameras with production date 2018 or newer (serials starting with 18 or higher) are equipped with an additional 5th mounting hole in the upper center of the rectangular M4 hole pattern. If your camera comes with five M4 mounting holes it is recommended to use a triangular mounting pattern with three M4 screws and the supplied DIN433 distance washers for additional robustness against deformation of the camera housing. This is especially important when pressing the camera against a planar surface.
